1. Dashboard
  2. Artikel
  3. Mitglieder
    1. Letzte Aktivitäten
    2. Benutzer online
    3. Team
    4. Mitgliedersuche
  4. Forum
    1. Unerledigte Themen
  • Anmelden
  • Registrieren
  • Suche
Dieses Thema
  • Alles
  • Dieses Thema
  • Dieses Forum
  • Artikel
  • Seiten
  • Forum
  • Erweiterte Suche
  1. HTML - Webmaster Forum
  2. HTML / Webmaster Forum
  3. HTML & CSS Forum
Validator Problem
  • Megabiker
  • 1. April 2009 um 20:50
  • Megabiker
    Schüler
    • 3. April 2009 um 00:52
    • #21
    nun sind es nur noch 3, kann mir bei denen jemand helfen?
    Zitat
    • [Blockierte Grafik: http://validator.w3.org/images/info_icons/error.png]Line 12, Column 28: Attribute "lang" exists, but can not be used for this element. <meta name="keywords" lang="de, at, ch" content="Mountainbike, Forum, Fahrrad, C ✉
      You have used the attribute named above in your document, but the document type you are using does not support that attribute for this element. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Transitional" document type to get the "target" attribute), or by using vendor proprietary extensions such as "marginheight" (this is usually fixed by using CSS to achieve the desired effect instead).
      This error may also result if the element itself is not supported in the document type you are using, as an undefined element will have no supported attributes; in this case, see the element-undefined error message for further information.
      How to fix: check the spelling and case of the element and attribute, (Remember XHTML is all lower-case) and/or check that they are both allowed in the chosen document type, and/or use CSS instead of this attribute. If you received this error when using the <embed> element to incorporate flash media in a Web page, see the FAQ item on valid flash.
    Keine Ahnung was da gemeint ist...
    Gruß MEGA
    Mein Multicopter Forum: Drohnen-Forum.eu
  • driver
    Reaktionen
    6
    • 3. April 2009 um 07:49
    • #22
    willst du für jedes deiner validator-probleme jetzt eigentlich nen
    thread aufmachen ? benutz doch einfach mal google. da wirste
    ganz schnell feststellen, dass es keinen meta-tag "lang" gibt.
    so sollte es heißen
    [B][B][B]<meta name="language"  content="deutsch, de">[/B][/B][/B]
    [B]bzw[/B]
    [B]<meta http-equiv="language" content="deutsch, de">[B][B]
    [/B][/B][/B]
    btw. da ich ja kein quellcode sehe.. hast du wirklich alle angaben in ein metatag
    geschrieben ? wenns wirklich so is lies dir mal dies durch, oder lass dir
    deine tags gleich hier erstellen.
    [Blockierte Grafik: http://www.devil-driver.de/stuff/forum-banner.png]
  • Megabiker
    Schüler
    • 3. April 2009 um 08:19
    • #23
    Ich habe das Problem mit den Metas Gelöst, nun bekam ich aber von einem Benutzer eine Mail das die Werbebannerchen bei Ihm alle untereinander kommen würden, ich habe nun selber mal mit dem Safari explorer gekuckt, da ist das auch so...
    Was kann das sein, das css sieht so aus:
    PHP
    #banner li {
    list-style-type: none;
    margin-bottom: 5px;
    float:right;
    Gruß MEGA
  • driver
    Reaktionen
    6
    • 3. April 2009 um 08:24
    • #24
    hm, also bei mir im ff waren die banner gerade auch noch
    untereinander. hab dann mal mein cache geleert, jetzt passt
    das ganze wieder. evtl muss er nurmal die seite neu laden :|
  • Megabiker
    Schüler
    • 3. April 2009 um 08:36
    • #25
    Ja, ich habe Ihm das geschrieben nun funktionierst:D. Beim Safari im übrigen auch...
    Gruß MEGA
  • Elvis
    • 3. April 2009 um 19:11
    • #26
    Die Links sind jetzt aber nicht so klasse....
    Bitte nicht klicken!
    Fighting for Webstandards!
    Du bist Terrorist
  • Megabiker
    Schüler
    • 3. April 2009 um 19:18
    • #27
    Welche Links meinst Du?
    Gruß MEGA
  • Elvis
    • 3. April 2009 um 19:59
    • #28
    Die aus dem Zitat....
    Du bist Terrorist
  • Megabiker
    Schüler
    • 4. April 2009 um 06:25
    • #29
    Kann man eigentlich ein HTML Dokument in XHTML einbinden ohne das der Validator meckert?
    z.B. eine Grafik ohne alt="" oder Banner
    Gruß MEGA
  • Elvis
    • 4. April 2009 um 11:14
    • #30
    1. Ein Bild/eine Grafik ist kein HTML-Dokument.
    2. Das alt-Attribut ist fester Bestandteil des <img>-Tags. Das war in HTML so und wird vermutlich auch in XXHTML so sein.
    3. Du musst jetzt nicht Deine nicht mal zugelassene Sprache XHTML 1.1 auf HTML 4.01 runterbrechen nur damit der Validator nicht mehr meckert. Benutze einfach die zugelassenen und aktuellen Versionen (HTML 4.01 und XHTML 1.0) mit entsrechender Sachkenntnis der entsprechenden Tags, so wie es die Semantische Textauszeichnung vorsieht.
    4. Das Stichwort was Du suchst (aber nicht brauchst) ist Doctype-Switching.
    Du bist Terrorist
  • Megabiker
    Schüler
    • 4. April 2009 um 11:18
    • #31
    Das Problem ist ganz einfach das, das ich die Werbebanner von Afilli Net nicht ändern darf, und die sind eben nicht in XHTML (bzw. jetzt schon, aber ob das OK ist:D).
    Deshalb muss ich da irgendwie umschalten, sonst bekomme ich evtl Probleme.
    Wie soll das Funktionieren?
    Gruß MEGA
  • Elvis
    • 4. April 2009 um 11:40
    • #32
    Gegen ein Anpassung des Werbelinks kann Dein Affilate-Partner nichts haben, solange Du die Funktionalität nicht einschränkst.
    Du bist Terrorist
  • Megabiker
    Schüler
    • 4. April 2009 um 12:45
    • #33
    Ich hab das jetzt mal durch den css (3.0) validator gejagt, der von Euch am anfang vorgeschlagene und funktionelle Code scheint einen Hacken zu haben:
    PHP
    #banner ul {
    align:right;
    #banner li {
    margin-bottom: 2px;
    float:right;
    Die Validation spuckt folgenden Fehler aus:
    #banner ul Die Eigenschaft align existiert nicht : right
    Was muss ich da ändern, der Code oben ist genau so wie ich ihn auf der Website habe...
    Gruß MEGA
  • threadi
    Reaktionen
    4
    • 4. April 2009 um 13:29
    • #34
    Es heißt text-align (horizontale Ausrichtung) oder vertical-align (vertikale Ausrichtung) nicht align.
  • Megabiker
    Schüler
    • 4. April 2009 um 13:35
    • #35
    OK, danke Funktioniert:)
    Gruß MEGA
  • Megabiker
    Schüler
    • 6. April 2009 um 09:14
    • #36
    Neues Problem! Validome meckert über € Zeichen... Was nun?
    (Die Seite ist übrigens jetzt XHTML 1.0)
    Gruß MEGA
  • driver
    Reaktionen
    6
    • 6. April 2009 um 09:22
    • #37
    versuchs mal so &euro; oder so & #8364; (leerstelle weglassen)
  • Megabiker
    Schüler
    • 6. April 2009 um 09:38
    • #38
    Geht nicht, gibt es da keine andre Lösung, der Beitrag wurde von einem Forenmitglied geschrieben, ich kann doch nicht verbieten Euro-Zeichen in der Überschrift der Kaufberatung zu verwenden:shock:.
    So ein Mist mal wieder; 1. kommt es anders und 2. als man denkt:(
    Gruß MEGA
  • Bandit
    • 6. April 2009 um 09:48
    • #39
    Da wirst du in die Forensoftware eingreifen müssen und solche Zeichen mit PHP ersetzen oder alles auf UTF-8 umstellen
  • Megabiker
    Schüler
    • 6. April 2009 um 20:29
    • #40
    Nun habe ich was das ich wirklich nicht hinbekomme, ich brauche diesen Code XHTML 1,0 kompatibel:
    PHP
      <td><a href="http://www.zweiradsuche.de"><font face="Arial" size="5"><b>ZWEIRADSUCHE.DE</b><br /><font size="1"><b>Der Webkatalog für Zweiradseiten</b></font><br></a></td>
      <td>www.zweiradsuche.de</td>
    kann mir da jemand helfen?
    Gruß MEGA
Tags
  • www
  • banner
  • homepage
  • html
  • http
  • online
  • style
  • web
  • quellcode
  • text
  • problem
  • code
  • tag
  • ban
  • bot
  • bottom
  • google
  • suchmaschinen
  • optimierung
  • px
  • align
  • validator
  • float
  1. Datenschutzerklärung
  2. Impressum
