Ergebnis 1 bis 2 von 2
Thema: Bildupload Problem
    Standard Bildupload Problem
    ich habe ein Problem beim Bildupload, genauer gesagt nachdem ich das Bild von der Größe her angepasst habe speichert es nicht das geänderte Bild ab.
    Ich habe den Max's Picture Uploader Script verwendet und für mich angepasst.
    maxImageUpload.class.php:
     * Max's Image Uploader
     * Version: 1.0
     * Date: 2008-03-18
    class maxImageUpload {
    // Maximum upload size
    var $maxUploadSize 2// 2 Mb
        // Image sizes
    var $normalWidth   220;
        var
    $normalHeight  0;
    //var $thumbWidth    = 128;
        //var $thumbHeight   =  96;
        // Image quality
    var $imageQualityNormal 3//1:Poor ... 5:Very good
        //var $imageQualityThumb  = 1; //1:Poor ... 5:Very good
        // Directories to store images
    var $baseDir     '';
        var
    $originalDir 'uploads';
        var
    $normalDir   'uploads/profil';
    //var $thumbDir    = 'thumbnail';
        // File postfixes
    var $originalPrefix '';
        var
    $normalPrefix   '';
    //var $thumbPrefix    = 'thumb_';
        // Internal used variables
    var $error '';
        var
    $maxMemoryUsage 128;  // 128 Mb
         * Constructor to initialize class varaibles
         * The upload locations will be set to the actual
         * working directory
         * @return maxImageUpload
    function maxImageUpload(){
           if (!
    file_exists($this->baseDir)) {
              if (!@
    mkdir($this->baseDir)){
    $this->baseDir getcwd();
    $this->originalDir $this->baseDir.DIRECTORY_SEPARATOR.$this->originalDir.DIRECTORY_SEPARATOR;
           if (!
    file_exists($this->originalDir)) {
    mkdir($this->originalDir);
    $this->normalDir $this->baseDir.DIRECTORY_SEPARATOR.$this->normalDir.DIRECTORY_SEPARATOR;
           if (!
    file_exists($this->normalDir)) {
    mkdir($this->normalDir);
    //       $this->thumbDir = $this->baseDir.DIRECTORY_SEPARATOR.$this->thumbDir.DIRECTORY_SEPARATOR;
    //       if (!file_exists($this->thumbDir)) {
    //          mkdir($this->thumbDir);
    //This function reads the extension of the file. It is used to determine if the file  is an image by checking the extension.
    function getExtension($str) {
    $i strrpos($str,".");
            if (!
    $i) { return ""; }
    $l strlen($str) - $i;
    $ext substr($str,$i+1,$l);
            return
    strtolower($ext);
         * This function sets the directory where to upload the file
         * In case of Windows server use the form: c:\\temp
         * In case of Unix server use the form: /tmp
         * @param String Directory where to store the files
    function setUploadBaseLocation($dir){
    $this->baseDir $dir;
        function
    showUploadForm($msg='',$error=''){
    require_once(
    'header.php');
    <div id="content">
    <div class="left">
    <div class="articles">
    if ($msg != ''){
        echo
    '<p class="msg">'.$msg.'</p>';
    } else if (
    $error != ''){
        echo
    '<p class="emsg">'.$error.'</p>';
                    <br />
                    <form action="" method="post" enctype="multipart/form-data" >
                         <center>
                             <label>Datei:
                                 <input name="myfile" type="file" size="30" />
                             </label>
                             <br />
                             <br />
                             <label>
                                 <input type="submit" name="submitBtn" class="sbtn" value="Hochladen" />
                             </label>
                         </center>
    require_once('mainnav.php');
    require_once(
    'footer.php');
        function
    uploadImage(){
    $result true;
            if (!isset(
    $_POST['submitBtn'])){
    $this->showUploadForm();
            else {
    $msg '';
    $error '';
    //Check image type. Only jpeg images are allowed
    if ( (($_FILES['myfile']['type'])=='image/pjpeg') || (($_FILES['myfile']['type'])=='image/jpeg'))
    // Check the output directories
    if ($this->checkDirs()){
    $target_path $this->originalDir.basename$_SESSION["user_nickname"]."."$this->getExtension($_FILES['myfile']['name']));
                       if(@
    move_uploaded_file($_FILES['myfile']['tmp_name'], $target_path)) {
    $msg basename$_SESSION["user_nickname"]."."$this->getExtension($_FILES['myfile']['name'])).
    " (".filesize($target_path)." bytes) gespeichert!";
                       } else{
    $error "Der Upload ist fehlgeschlagen!";
    $result false;
    // Store resized images
    if ($result)
    $this->setMemoryLimit($target_path);
    // Create normal size image
    $dest $this->normalDir.basename$_SESSION["user_nickname"]."."$this->getExtension($_FILES['myfile']['name']));
    $this->resizeImage($target_path,$dest,$this->normalWidth,$this->normalHeight,$this->imageQualityNormal);
    $msg .= "<br/>".basename($dest)." (".filesize($dest)." bytes) gespeichert!";
    //                      // Create thumbnail image
    //                      $dest = $this->thumbDir.$this->thumbPrefix.basename($_FILES['myfile']['name']);
    //                      $this->resizeImage($target_path,$dest,$this->thumbWidth,$this->thumbHeight,$this->imageQualityThumb);
    //                      $msg .= "<br/>".basename($dest)." (".filesize($dest)." bytes) was stored!";
                    else {
                           echo
    "Nur .jpeg Bilder sind erlaubt!";
    $this->showUploadForm($msg,$error);
        function
    checkDirs()
    $result true;
           if (!
    $this->error "The target directory ($this->originalDir) doesn't exists!";
    $result false;
           } else if (!
    is_writeable($this->originalDir))
    $this->error "The target directory ($this->originalDir) is not writeable!";
    $result false;
            else if (!
    is_writeable($this->normalDir)) {
    $this->error "The target directory ($this->normalDir) is not writeable!";
    $result false;
           } else if (!
    $result false;
    //        else if (!is_writeable($this->thumbDir)) {
    //          $this->error = "The target directory ($this->thumbDir) is not writeable!";
    //          $result = false;
    else if (!is_writeable($this->originalDir))
    $this->error "The target directory ($this->thumbDir) is not writeable!";
    $result false;
           return
    $result;
        function
    setMemoryLimit($filename){
    $width  0;
    $height 0;
    $size   ini_get('memory_limit');
           list(
    $width$height) = getimagesize($filename);
    $size $size floor(($width $height 1.5 1048576) / 1048576);
           if (
    $size $this->maxMemoryUsage$size $this->maxMemoryUsage;
    ini_set('memory_limit',$size.'M');
        function
    resizeImage($src,$dest,$new_width,$new_height,$quality)
    $width  0;
    $height 0;
            list(
    $width$height) = getimagesize($src);
            if(
    $new_height 0)
    $new_height round(($height/$width)*$new_width,0);
    $newImage imagecreatetruecolor($new_width$new_height);
    $oldImage imagecreatefromjpeg($src);
    $this->fastimagecopyresampled($newImage$oldImage0000$new_width$new_height$width$height$quality);
    imagejpeg($newImage$dest100);
    // Function to resize images
        // Author: Tim Eckel - Date: 12/17/04 - Project: FreeRingers.net - Freely distributable.
    function fastimagecopyresampled (&$dst_image$src_image$dst_x$dst_y$src_x$src_y$dst_w$dst_h$src_w$src_h$quality 3) {
           if (empty(
    $src_image) || empty($dst_image)) { return false; }
           if (
    $quality <= 1) {
    $temp imagecreatetruecolor ($dst_w 1$dst_h 1);
    imagecopyresized ($temp$src_image$dst_x$dst_y$src_x$src_y$dst_w 1$dst_h 1$src_w$src_h);
    imagecopyresized ($dst_image$temp0000$dst_w$dst_h$dst_w$dst_h);
    imagedestroy ($temp);
           } elseif (
    $quality && (($dst_w $quality) < $src_w || ($dst_h $quality) < $src_h)) {
    $tmp_w $dst_w $quality;
    $tmp_h $dst_h $quality;
    $temp imagecreatetruecolor ($tmp_w 1$tmp_h 1);
    imagecopyresized ($temp$src_image$dst_x $quality$dst_y $quality$src_x$src_y$tmp_w 1$tmp_h 1$src_w$src_h);
    imagecopyresampled ($dst_image$temp0000$dst_w$dst_h$tmp_w$tmp_h);
           } else {
    imagecopyresampled ($dst_image$src_image$dst_x$dst_y$src_x$src_y$dst_w$dst_h$src_w$src_h);
           return
    true;
    Der Dateiname soll den Benutzernamen annehmen. Das Original wird auch gespeichert. beide Ordner (uploads und uploads/profil) sind auf 777 (chmod) eingestellt.
    Aufruf der Klasse mit der PHP-Datei (Uploader.php):
    include ("checkuser.php");
    require_once(
    "maxImageUpload.class.php");
        $myImageUpload
    = new maxImageUpload();
    $myImageUpload->uploadImage();
    Standard AW: Bildupload Problem
    Problem hat sich gelöst, wenn ich den Originalnamen der Bilddatei nehme erscheint dann eine Fehlermeldung (vorher gar nicht).
    Die Lösung des Problems ist die Änderung dieser Zeile.
    maxImageUpload.php:
    if(intval($new_height) == 0
    Geändert von Mic4 (18.02.2011 um 16:33 Uhr)
  1. Bildupload PNG
    Von Thonixx im Forum Forum-Hilfe.de intern
    Letzter Beitrag: 17.08.2009, 13:59
  2. PHP Warnung Bildupload
    Letzter Beitrag: 17.08.2009, 08:27
  3. Problem bei Bildupload ->Reihenfolge der Funktionen
    Von jojo87 im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Letzter Beitrag: 12.04.2008, 13:13
  4. Suche Anwendung für Bildupload
    Von strauberry im Forum Flash Forum
    Letzter Beitrag: 18.06.2007, 17:04
  5. Wasserzeichen beim Bildupload
    Letzter Beitrag: 04.05.2006, 11:39
