Ergebnis 1 bis 10 von 15
Thema: Undefined Index error in 2 zeilen eines fertig scriptes
    Idee
    Hallo zusammen ichh abe folgendes Problem ich habe fuer php fusion v7 eine infusion nach Anleitung eingebaut.
    Nach Panel aktivierung kommen jedoch folgende fehlermeldungen
    Notice: Undefined index: history in C:\Inetpub\vhosts\fly-wow.de\httpdocs\infusions\letztesongs_panel\letzte songs_panel.php on line 28
    Notice: Undefined index: listener in C:\Inetpub\vhosts\fly-wow.de\httpdocs\infusions\letztesongs_panel\letzte songs_panel.php on line 35
    als php code nutze ich folgenden
    | PHP-Fusion Content Management System
    | Copyright © 2002 - 2008 Nick Jones
    | http://www.php-fusion.co.uk/
    | Letzte Songs Panel for PHP-Fusion v7
    | Author: Christian Krause (ckoneman04)
    | Homepage: http://www.djchrissi.de.ms
    | This program is released as free software under the
    | Affero GPL license. You can redistribute it and/or
    | modify it under the terms of this license which you
    | can read by viewing the included agpl.txt or online
    | at www.gnu.org/licenses/agpl.html. Removal of this
    | copyright header is strictly prohibited without
    | written permission from the original author(s).
    opensidex("History","on");
    // HIER DIE SERVERDATEN EINGEBEN
    $scast_host '****************';      // SHOUTCAST HOST IP
    $scast_port '8000';              // SHOOUTCAST PORT
    $scast_pass '**************';  // SHOUTCAST ADMIN PASSWORT
    if ($_REQUEST['history']) {
    $show_sc_songhistory 1;
    else {
    if (
    $_REQUEST['listener']) {
    $show_sc_listeners 1;
    else {
        if(
    $fp = @fsockopen($scast_host$scast_port$errno$errstr30)) {
            if(
    fputs($fp"GET /admin.cgi?pass=".$scast_pass."&mode=viewxml HTTP/1.0\r\nUser-Agent: XML Getter (Mozilla Compatible)\r\n\r\n")) {
    $xmldata "";
                while(!
    feof($fp)) $xmldata .= fgets($fp1000);
    $xmldata explode("\r\n"$xmldata);
    $xmldata $xmldata[3];
        function
    get_item($name$source) {
    preg_match('#<'.$name.'>(.*?)</'.$name.'>#'$source$matches);
            return
    $matches[1];
        function
    get_items($name$source) {
    preg_match_all('#<'.$name.'>(.*?)</'.$name.'>#'$source$matches);
            return
    $matches[1];
    $sc_stream_status get_item("STREAMSTATUS"$xmldata);
        if(
    $sc_stream_status) {
    $sc_stream_bitrate get_item("BITRATE"$xmldata);
    $sc_listeners_cur  get_item("CURRENTLISTENERS"$xmldata);
    $sc_listeners_peak get_item("PEAKLISTENERS"$xmldata);
    $sc_listeners_max  get_item("MAXLISTENERS"$xmldata);
    $sc_server_title   get_item("SERVERTITLE"$xmldata);
    $sc_server_url     get_item("SERVERURL"$xmldata);
    $sc_server_genre   get_item("SERVERGENRE"$xmldata);
    $sc_server_version get_item("VERSION"$xmldata);
    $sc_current_song   get_item("SONGTITLE"$xmldata);
    $sc_irc            get_item("IRC"$xmldata);
    $sc_icq            get_item("ICQ"$xmldata);
    $sc_aim               get_item("AIM"$xmldata);
        if(!(
    $sc_stream_bitrate)) {
            echo
    "        Sorry, aber Server ist offline!" "\n";
        else {
            if (
    $show_sc_songhistory) {
                echo
    "\n" "        <center><h3>Songhistory</h3></center>" "\n";
                echo
    "        <center><table border=0></center>" "\n";
    $scast_songs get_items("SONG"$xmldata);
    $count 0;
                for(
    $i=0$i<count($scast_songs); $i++)
    $sc_song_playtime        strftime("%H:%M"get_item("PLAYEDAT"$scast_songs[$i]));
    $sc_song_title            get_item("TITLE"$scast_songs[$i]);
                    echo
    "                <tr><td>$sc_song_playtime</td><td>$sc_song_title</td></tr>" "\n";
                echo
    "        </table>" "\n";
            } else {
    $sc_songhistory "";
            if (
    $show_sc_listeners) {
                echo
    "\n" "        <h3>Zuhörer</h3>" "\n";
                echo
    "        <table border=1>" "\n";
                echo
    "                <tr><th>No.</th><th>Hostname</th><th>Useragent</th><th>Connecttime</th></tr>" "\n";
    $scast_listeners get_items("LISTENER"$xmldata);
    $count 0;
                for(
    $i=0$i<count($scast_listeners); $i++)
    $sc_no                      $i+1;
    $sc_hostname            get_item("HOSTNAME"$scast_listeners[$i]);
    $sc_useragent            get_item("USERAGENT"$scast_listeners[$i]);
    $sc_connecttime            gmstrftime("%H:%M:%S"get_item("CONNECTTIME"$scast_listeners[$i]));
                    echo
    "                <tr><td>$sc_no</td><td>$sc_hostname</td><td>$sc_useragent</td><td>$sc_connecttime</td></tr>" "\n";
                echo
    "        </table>" "\n";
            else {
    $sc_listeners "";
    closesidex();
    Ich hoffe ihr koennt mir ssagen was ich falsch gemacht habe ?
    Vielen dank schon im vorraus für eure Mühen
    sichtbar auf http://www.fly-wow.de
    in linker navi leiste
    Geändert von synaptic (26.04.2010 um 21:32 Uhr) Grund: doppelposts zusammengefasst nutz bitte die editierfunktion -synaptic-
    Standard AW: Undefined Index error in 2 zeilen eines fertig scriptes
    if ($_REQUEST['history']) => if (isset($_REQUEST['history']))
    if ($_REQUEST['listener']) => if (isset($_REQUEST['listener']))
    Pion
    Hier tut es isset aber in Zukunft lieber !empty verwenden den da prüft es auch den Inhalt
    Meister(in) Avatar von Afrael
    NRW
    empty wirft aber immer noch die Notice. Wenn schon, dann beide.
    Don't eat unpeeled hedgehogs.
    Pion
    error_reporting(E_ALL);
    if (!empty($_REQUEST['history'])) {
        $show_sc_songhistory = 1;
    Mit empty muss man aber auch aufpassen:
       $x
    0;
       if (empty(
    $x))
          echo
    "Empty";
          echo
    "Not Empty";
    Da kommt Empty raus und das kann u.U. nicht gewollt sein.
    Danke euch fuer die vielzahl an Antworten werede es heute abend zuhause dann mal austesten
    mfg chris
    ich habe es geschafft mit der isset funktion danke euch
    $scast_host 'fly-wow.de';      // SHOUTCAST HOST IP
    $scast_pass 'xx5x4b3';  // SHOUTCAST ADMIN PASSWORT
    if (isset($_REQUEST['history'])){
    else {
    if (isset(
    $_REQUEST['listener'])){
    else {
        if(
            if(
    $xmldata "";
                while(!
        function
            return
    $matches[1];
        function
            return
    $matches[1];
        if(isset(
    $sc_stream_status)) {
        if(!(
            echo
    "        Server offline!" "\n";
        else {
            if (
                echo
    "\n" "        <center><h3><font color="red">Titelspeicher</font></h3></center>" "\n";
                echo
    $count 0;
                for(
                    echo
                echo
    "        </table>" "\n";
            } else {
    $sc_songhistory "";
            if (
                echo
    "\n" "        <h3><font color="red">Zuhoerer</font></h3></center></h3>" "\n";
                echo
                echo
    "                <tr><th>No.</th><th>Connecttime</th></tr>" "\n";
    $count 0;
                for(
    $sc_no                      $i+1;
                    echo
    "                <tr><td>$sc_no</td><td>$sc_connecttime</td></tr>" "\n";
                echo
    "        </table>" "\n";
            else {
    $sc_listeners "";
    closesidex();
    so sieht es nun aus hat noch jemand eine Idee zur weitern verinfachung? LG und netten abend noch christian
    NRW
    else {
    if (isset(
    else {
    ??? Soll das später konfigurierbar sein? Wenn nein, nimm doch einfach
  1. index.php vor index.html interpretieren. Mit Plesk Zugriff auf /conf/ genehmigen?
    Von mikonos im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Letzter Beitrag: 02.03.2010, 11:54
  2. Notice: Undefined index
    Von Shyne im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Letzter Beitrag: 07.03.2008, 22:23
  3. Problem mit instaallation eines Scriptes
    Von aimer im Forum HTML & CSS Forum
    Letzter Beitrag: 15.08.2007, 08:18
  4. Antworten: 2
    Letzter Beitrag: 05.11.2006, 10:55
  5. Vergleich auf undefined
    Von Torty im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Letzter Beitrag: 01.04.2005, 10:48
