Thema: Kontak Formular Problem
    Under-Cover
    Standard Kontak Formular Problem
    Hey leute also..
    habe unten einen code..undzwar kontakt formular..was muss ich machen
    das die anmeldung an meine email adresse kommt?
    <meta http-equiv="Content-Language" content="de" />
    <meta http-equiv="Content-Type" content="text/html; charset=windows-1252" />
    <form action="--WEBBOT-SELF--" method="post" name="&#91;object&#93;">
    </p>
    </p>
    </p>
        <table id="AutoNumber1" style="BORDER-COLLAPSE&#58; collapse" bordercolor="#111111" height="105" cellspacing="0" cellpadding="0" width="100%" border="0">
            <tbody>
                    <td width="1%" height="22">Name&#58;</td>
                    <td width="14%" height="22"><input name="name" type="text" /></td>
                    <td width="34%" colspan="2" height="22"></td>
                    <td width="61%" colspan="2" height="22"></td>
                    <td width="1%" height="22">Telefon&#58;</td>
                    <td width="14%" height="22"><input name="telefon" type="text" /></td>
                    <td width="1%" height="22">E-Mail</td>
                    <td width="14%" height="22"><input name="email" type="text" /></td>
                    <td width="1%" height="19"></td>
                    <td width="14%" height="19"></td>
                    <td width="34%" colspan="2" height="19"></td>
                    <td width="61%" colspan="2" height="19"></td>
                    <td width="6%" height="20">Tag&#58;</td>
                    <td width="14%" height="20"><select size="1" name="D1">
                    <option value="1" selected="selected">1</option>
                    <option value="2">2</option>
                    <option value="3">3</option>
                    <option value="4">4</option>
                    <option value="5">5</option>
                    <option value="6">6</option>
                    <option value="7">7</option>
                    <option value="8">8</option>
                    <option value="9">9</option>
                    <option value="10">10</option>
                    <option value="11">11</option>
                    <option value="12">12</option>
                    <option value="13">13</option>
                    <option value="14">14</option>
                    <option value="15">15</option>
                    <option value="16">16</option>
                    <option value="17">17</option>
                    <option value="18">18</option>
                    <option value="19">19</option>
                    <option value="20">20</option>
                    <option value="21">21</option>
                    <option value="22">22</option>
                    <option value="23">23</option>
                    <option value="24">24</option>
                    <option value="25">25</option>
                    <option value="26">26</option>
                    <option value="27">27</option>
                    <option value="28">28</option>
                    <option value="29">29</option>
                    <option value="30">30</option>
                    <option value="31">31</option>
                    </select></td>
                    <td width="6%" height="20">Monat&#58;</td>
                    <td width="6%" height="20"><select size="1" name="D2">
                    </select></td>
                    <td width="3%" height="20">Jahr&#58;</td>
                    <td width="65%" height="20"><input name="jahr" type="text" /></td>
            </tbody>
    <input type="submit" name="B1" value="Abschicken" /><input type="reset" name="B2" value="Zurücksetzen" /></p>
    Dankee
    Max F.
    http://www.forum-hilfe.de/viewtopic.php?t=32042 schau mal da
    dein code muss den Befehlt action="*.php" aufführen, damit sie die .php datei ausführt um die Mail zu schicken.
    Die .php Datei kannst du dir unter dem oberen Link herunterladen.
    musst die Datei nur an dein Formular anpassen.
    MfG
    Max
    C:\deinPfad\private\form_results.csv würd ich ebenfalls überdenken,
    oder is deine seite noch lokal gespeichert ?
    also lokal funkt php nicht (es sei denn du hast bei dir nen webserver laufen).
    also erstmal uploaden, dann pfade anpassen.....
  1. Formular Problem
    Von Tom1989m im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Antworten: 25
    Letzter Beitrag: 26.11.2007, 13:11
  2. Formular Problem
    Letzter Beitrag: 09.04.2007, 14:41
  3. Skype Kontak bei Ebay einbauen
    Von Anonymer im Forum HTML & CSS Forum
    Letzter Beitrag: 15.02.2007, 22:26
  4. Problem mit Formular
    Von Karunaa im Forum HTML & CSS Forum
    Letzter Beitrag: 07.09.2006, 07:39
  5. Problem mit formular
    Von icebaby im Forum PHP Forum - Apache - CGI - Perl - JavaScript und Co.
    Letzter Beitrag: 24.07.2006, 18:16
