Ergebnis 1 bis 10 von 12
Thema: problem mit dem menü
    Standard problem mit dem menü
    hallo...!
    ich habe folgendes problem...mein menü bewegt sich jedesmal, wenn ich einen langen text schreibe...ich habe alles mögliche versucht und komm nicht weiter...bin nur ein armseliger html anfänger
    hier der code:
    [code]<html>
    <style>
    A:link {text-decoration: none;}
    A:visited {text-decoration: none;}
    A:active {text-decoration: none;}
    A:hover {text-decoration: none;}
    <title>Home</title>
    <BODY TEXT="#FF0000" LINK="#FF0000" VLINK="#FF0000" ALINK="#4169E1" bgcolor=black text=FF0000>
    <font face="Monotype Corsiva" size= color=red>
    <H2>
    <center>
    <font size="30" color="#65FD00">
    BLacK kRasY
    </font>
    <sup>
    <font size="5" color="#2F34F9">
    &nbsp&nbsp&nbsp&nbsp&nbsp&#8482
    </font>
    </sup>
    </H1>
    </center>
    <center>
    <script>
    // CREDITS:
    // Inline clock: fits anywhere into any text
    // by Urs Dudli and Peter Gehrig
    // Copyright (c) 2000 Peter Gehrig and Urs Dudli. All rights reserved.
    // Permission given to use the script provided that this notice remains as is.
    // Additional scripts can be found at http://www.24fun.com
    // info@24fun.com
    // 7/5/2001
    // IMPORTANT:
    // If you add this script to a script-library or a script-archive
    // you have to insert a link to http://www.24fun.com
    // right into the webpage where the script will be displayed.
    // CONFIGURATION:
    // Go to http://www.24fun.com, open category 'date' and
    // download the ZIP-file of this script containing
    // the script-file with step-by-step instructions for easy configuration
    var clockid=new Array()
    var clockidoutside=new Array()
    var i_clock=-1
    var thistime= new Date()
    var hours=thistime.getHours()
    var minutes=thistime.getMinutes()
    var seconds=thistime.getSeconds()
    if (eval(hours) <10) {hours="0"+hours}
    if (eval(minutes) < 10) {minutes="0"+minutes}
    if (seconds < 10) {seconds="0"+seconds}
    var thistime = hours+":"+minutes+":"+seconds
    function writeclock() {
    i_clock++
    if (document.all || document.getElementById || document.layers) {
    clockid[i_clock]="clock"+i_clock
    document.write("<font family=Monotype Corsiva size=7 color=#00FA9A><span id='"+clockid[i_clock]+"' style='position:relative'>"+thistime+"</span></font>")
    function clockon() {
    if (document.all) {
    for (i=0;i<=clockid.length-1;i++) {
    var thisclock=eval(clockid[i])
    thisclock.innerHTML=thistime
    if (document.getElementById) {
    document.getElementById(clockid[i]).innerHTML=thistime
    var timer=setTimeout("clockon()",1000)
    window.onload=clockon
    </script>
    <table border="0">
    <td>
    <sup>
    <font size=10 color="red">
    <u>
    family
    </u>
    &nbsp
    </font>
    </sup>
    <script>writeclock()</script></font>
    </td>
    </center>
    <hr>
    Gratis Counter<script type="text/javascript" language="JavaScript" src="http://www.skoom.de/gratis-counter/red.php?id=30593"></script></align>
    <table>
    <td>
    <font bgcolor="#0628EA" face="Monotype Corsiva">
    <table cellspacing="4" cellpadding="4">
    <center>
    <tr bgcolor="#000000">
    <td>
    </td></tr>
    </center>
    </td>
    <td style="padding-left:60px;">
    <center>
    <center>
    </center>
    <center>
    <--! links dürft ihr leider net benutzen, sry>
    Dies ist nur nen test für die schrift aber ich komm damit nicht klar...die navigationsbar bewgt sich i-wie immer mit!die soll aber soo bleiben wie sie ist...
    auch alles andere
    llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll llll
    kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
    </center>
    fallrad
    Das Ewige Nichts...
    hmmmm....also sorry ich weiß nicht was du meinst ?!Wenn ich das bei mir mal probiere dann kommt dieses kkkllll zeugs ziemlich links und die Buttons ohne Text!
    Aber ich weiß nicht was du mit bewegen meinst !
    Kannst du das bitte mal ein wenig mehr erläutern ... Dankeschön
    MFG Martin
    http://www.web-banana.net
    ^^geht mal bitte drauf und registriert euch °_°!
    My sItE: Freakmartin.dl.am
    .~'*FH1-Style User*'~..~'*Gimp-User*'~..~'*Forum-hilfe-User*'~..~'*ICQ-User*'~..~'*Tutorial-User*'~.
    also....es hat ein grund des die buttons ohne text sind weil ihr die seiten net lesen sollt ^^.....genau des was du rausbekamst is auch richtig...
    also wenn ich nen text schreibe der kurz is is alles ganz normal, aber wenn ich sooo viel schreib wie des mit dem kkklll zeugs dann geht das menü auch mit
    dieses menü soll oben unter dem counter immer stehen bleiben egal wie viel text ich hab....
    Das Ewige Nichts...
    Wüsste grad glaube ich ne Lösung ...bin aber auf dem weg zum Kumpel hab deswegen 0 time!Wenn dir heut Abend niemand mehr helfen kann probier ichs mal morgn !!!!
    MFG MARTIn
    kay kay... thx schon ma im vorraus hehe
    zuerstmal quelltext bereinigen. da is ne menge überflüssiges zeug drin.
    für des menü würd ich mal sagen du machst nen divcontainer und
    positionierst ihn absolut mit top und left an die richtige position...
    <div id="menu">...inhalt des menüs...</div>
    und oben ins <style..>
    #menu &#123;
    position&#58;absolute;
    top&#58;xxx;
    left&#58;xxx;
    jo thx aba das menü ist davon trotzdem net bessa geworden...bleibt eigt nur da wo es is... gibt es net sowas wo man
    __________________________________________________ ________________
    | und ne andere spalte
    eine spalte |
    _________________|________________________________ _________
    das machen kann?
    sorry, vergessen. du musst des menü aus der tabelle rausnehmen.
    oder (jetzt mal schnell hinfantasiert), du machst unter des menü noch ne
    leere zelle und setzt dann beim inhalt den rowspan auf menuzeilen+1.
    die zeilen im menü machste mit height fix und die letzt lässte variable..
    raff ich net....kannst du des ma hin schreiben...
    also ich habs denk ich ma so kapiert...
    rowspan="+1"
    wenn ich die tabelle rausnehem funzt das bei mir nemmer.... wie soll das gehen....
  1. Drop-Down-Menü Problem IE6
    Von SPMan im Forum HTML & CSS Forum
    Letzter Beitrag: 29.05.2007, 19:33
  2. Pop up menü Problem
    Letzter Beitrag: 02.10.2006, 22:30
  3. js menü problem. refresh
    Von Bulldog2006 im Forum HTML & CSS Forum
    Letzter Beitrag: 26.04.2006, 11:29
  4. Problem mit Liste / Menü
    Von Knorkator im Forum HTML & CSS Forum
    Letzter Beitrag: 06.12.2004, 07:43
  5. Problem mit Menü
    Von Nixchecker im Forum HTML & CSS Forum
    Letzter Beitrag: 04.07.2004, 21:15
