hallo,
wieder ein problem:
ich habe ein dhtml menü und darunter einen iframe mit dem namen "hauptframe".
nun trage ich den namen des frames an die dafür vorgesehene stelle im script ein. allerdings wird der link nicht im frame geladen, sondern immer nur per _self.
hier der quelltext der menüs:
<script type='text/javascript'>
function Go(){return}
Menu1=new Array("Home","start.html","hier soll laut beschreibung der zielframe rein",0,20,96);
Menu2=new Array("News","http://","",0,0,100);
Menu3=new Array("Herren","http://","",2,0,100);
Menu3_1=new Array("Bundesliga","http://","",4,20,120);
Menu3_1_1=new Array("Spieler","http://","",0,20,120);
Menu3_1_2=new Array("Ergebnisse","http://","",0,20,0);
Menu3_1_3=new Array("Scorer","http://","",0,20,0);
Menu3_1_4=new Array("Spielplan","http://","",0,20,0);
Menu3_2=new Array("Regionalliga","http://","",4,20,0);
Menu3_2_1=new Array("Spieler","http://","",0,20,120);
Menu3_2_2=new Array("Ergebnisse","http://","",0,20,0);
Menu3_2_3=new Array("Scorer","http://","",0,20,80);
Menu3_2_4=new Array("Spielplan","http://","",0,20,80);
Menu4=new Array("Damen","http://","",4,0,100);
Menu4_1=new Array("Spielerinnen","http://","",0,20,120);
Menu4_2=new Array("Ergebnisse","http://","",0,20,0);
Menu4_3=new Array("Scorer","http://","",0,20,0);
Menu4_4=new Array("Spielplan","http://","",0,20,0);
Menu5=new Array("Jugend","http://","",0,0,100);
Menu6=new Array("Interaktiv","http://","",5,0,100);
Menu6_1=new Array("Gästebuch","http://","",0,20,120);
Menu6_2=new Array("Forum","http://","",0,20,0);
Menu6_3=new Array("Links","http://","",0,20,0);
Menu6_4=new Array("Berichte","http://","",3,20,0);
Menu6_4_1=new Array("Bericht1","http://","",0,20,120);
Menu6_4_2=new Array("Bericht2","http://","",0,20,0);
Menu6_4_3=new Array("Bericht3","http://","",0,20,80);
Menu6_5=new Array("Fotoecke","http://","",0,20,0);
Menu7=new Array("Kontakt","http://","",0,0,100);
Menu8=new Array("Sponsoren","http://","",0,20,100);
Menu9=new Array("Impressum","http://","",0,20,100);
Menu10=new Array("Intern","http://","",0,20,68);
var NoOffFirstLineMenus=10; // Number of first level items
var LowBgColor='4B6CA6'; // Background color when mouse is not over
var LowSubBgColor='869BBF'; // Background color when mouse is not over on subs
var HighBgColor='4B6CA6'; // Background color when mouse is over
var HighSubBgColor='F6F6F6'; // Background color when mouse is over on subs
var FontLowColor='000000'; // Font color when mouse is not over
var FontSubLowColor='000000'; // Font color subs when mouse is not over
var FontHighColor='F6F6F6'; // Font color when mouse is over
var FontSubHighColor='000000'; // Font color subs when mouse is over
var BorderColor='4B6CA6'; // Border color
var BorderSubColor='000000'; // Border color for subs
var BorderWidth=1; // Border width
var BorderBtwnElmnts=0; // Border between elements 1 or 0
var FontFamily="Arial" // Font family menu items
var FontSize=10; // Font size menu items
var FontBold=1; // Bold menu items 1 or 0
var FontItalic=0; // Italic menu items 1 or 0
var MenuTextCentered='left'; // Item text position 'left', 'center' or 'right'
var MenuCentered='center'; // Menu horizontal position 'left', 'center' or 'right'
var MenuVerticalCentered='top'; // Menu vertical position 'top', 'middle','bottom' or static
var ChildOverlap=.2; // horizontal overlap child/ parent
var ChildVerticalOverlap=.2; // vertical overlap child/ parent
var StartTop=0; // Menu offset x coordinate
var StartLeft=0; // Menu offset y coordinate
var VerCorrect=0; // Multiple frames y correction
var HorCorrect=0; // Multiple frames x correction
var LeftPaddng=0; // Left padding
var TopPaddng=0; // Top padding
var FirstLineHorizontal=1; // SET TO 1 FOR HORIZONTAL MENU, 0 FOR VERTICAL
var MenuFramesVertical=1; // Frames in cols or rows 1 or 0
var DissapearDelay=330; // delay before menu folds in
var TakeOverBgColor=1; // Menu frame takes over background color subitem frame
var FirstLineFrame='navig'; // Frame where first level appears
var SecLineFrame='space'; // Frame where sub levels appear
var DocTargetFrame='space'; // Frame where target documents appear
var TargetLoc=''; // span id for relative positioning
var HideTop=0; // Hide first level when loading new document 1 or 0
var MenuWrap=1; // enables/ disables menu wrap 1 or 0
var RightToLeft=0; // enables/ disables right to left unfold 1 or 0
var UnfoldsOnClick=0; // Level 1 unfolds onclick/ onmouseover
var WebMasterCheck=0; // menu tree checking on or off 1 or 0
var ShowArrow=0; // Uses arrow gifs when 1
var KeepHilite=1; // Keep selected path highligthed
var Arrws=['tri.gif',5,10,'tridown.gif',10,5,'trileft.gif',5, 10]; // Arrow source, width and height
var AgntUsr=navigator.userAgent.toLowerCase();
var DomYes=document.getElementById?1:0;
var NavYes=AgntUsr.indexOf('mozilla')!=-1&&AgntUsr.indexOf('compatible')==-1?1:0;
var ExpYes=AgntUsr.indexOf('msie')!=-1?1:0;
var Opr=AgntUsr.indexOf('opera')!=-1?1:0;
var Opr6orless=window.opera && navigator.userAgent.search(/opera.[1-6]/i)!=-1
var DomNav=DomYes&&NavYes?1:0;
var DomExp=DomYes&&ExpYes?1:0;
var Nav4=NavYes&&!DomYes&&document.layers?1:0;
var Exp4=ExpYes&&!DomYes&&document.all?1:0;
var PosStrt=(NavYes||ExpYes)&&!Opr6orless?1:0;
var FrstLoc,ScLoc,DcLoc;
var ScWinWdth,ScWinHght,FrstWinWdth,FrstWinHght;
var ScLdAgainWin;
var FirstColPos,SecColPos,DocColPos;
var RcrsLvl=0;
var FrstCreat=1,Loadd=0,Creatd=0,IniFlg,AcrssFrms=1;
var FrstCntnr=null,CurrntOvr=null,CloseTmr=null;
var CntrTxt,TxtClose,ImgStr;
var Ztop=100;
var ShwFlg=0;
var M_StrtTp=StartTop,M_StrtLft=StartLeft;
var StaticPos=0;
var LftXtra=DomNav&&!Opr?LeftPaddng:0;
var TpXtra=DomNav?TopPaddng:0;
var M_Hide=Nav4?'hide':'hidden';
var M_Show=Nav4?'show':'visible';
var Par=parent.frames[0]&&FirstLineFrame!=SecLineFrame?parent:window;
var Doc=Par.document;
var Bod=Doc.body;
var Trigger=NavYes&&!Opr?Par:Bod;
MenuTextCentered=MenuTextCentered==1||MenuTextCent ered=='center'?'center':MenuTextCentered==0||MenuT extCentered!='right'?'left':'right';
WbMstrAlrts=["Item not defined: ","Item needs height: ","Item needs width: "];
if(Trigger.onload)Dummy=Trigger.onload;
if(DomNav||Opr)Trigger.addEventListener('load',Go, false);
else Trigger.onload=Go;
function Dummy(){return}
function CnclSlct(){return false}
function RePos(){
FrstWinWdth=ExpYes?FrstLoc.document.body.clientWid th:FrstLoc.innerWidth;
FrstWinHght=ExpYes?FrstLoc.document.body.clientHei ght:FrstLoc.innerHeight;
ScWinWdth=ExpYes?ScLoc.document.body.clientWidth:S cLoc.innerWidth;
ScWinHght=ExpYes?ScLoc.document.body.clientHeight: ScLoc.innerHeight;
if(MenuCentered=='justify'&&FirstLineHorizontal){
FrstCntnr.style.width=FrstWinWdth;
ClcJus();
var P=FrstCntnr.FrstMbr,W=Menu1[5],i;
for(i=0;i<NoOffFirstLineMenus;i++){P.style.width=W ;P=P.PrvMbr}}
StaticPos=-1;
if(TargetLoc)ClcTrgt();
if(MenuCentered)ClcLft();
if(MenuVerticalCentered)ClcTp();
PosMenu(FrstCntnr,StartTop,StartLeft)}
function UnLoaded(){
if(CloseTmr)clearTimeout(CloseTmr);
Loadd=0; Creatd=0;
if(HideTop){
var FCStyle=Nav4?FrstCntnr:FrstCntnr.style;
FCStyle.visibility=M_Hide}}
function ReDoWhole(){
if(ScWinWdth!=ScLoc.innerWidth||ScWinHght!=ScLoc.i nnerHeight||FrstWinWdth!=FrstLoc.innerWidth||FrstW inHght!=FrstLoc.innerHeight)Doc.location.reload()}
function Check(WMnu,NoOf){
var i,array,ArrayLoc;
ArrayLoc=parent.frames[0]?parent.frames[FirstLineFrame]:self;
for(i=0;i<NoOf;i++){
array=WMnu+eval(i+1);
if(!ArrayLoc[array]){WbMstrAlrt(0,array); return false}
if(i==0){ if(!ArrayLoc[array][4]){WbMstrAlrt(1,array); return false}
if(!ArrayLoc[array][5]){WbMstrAlrt(2,array); return false}}
if(ArrayLoc[array][3])if(!Check(array+'_',ArrayLoc[array][3])) return false}
return true}
function WbMstrAlrt(No,Xtra){
return confirm(WbMstrAlrts[No]+Xtra+' ')}
function Go(){
Dummy();
if(Loadd||!PosStrt)return;
BeforeStart();
Creatd=0; Loadd=1;
status='Building menu';
if(FrstCreat){
if(FirstLineFrame =="" || !parent.frames[FirstLineFrame]){
FirstLineFrame=SecLineFrame;
FirstLineFrame=SecLineFrame=DocTargetFrame;
if(FirstLineFrame =="" || !parent.frames[FirstLineFrame])FirstLineFrame=SecLineFrame=DocTargetFrame=''}}
if(SecLineFrame =="" || !parent.frames[SecLineFrame]){
if(SecLineFrame =="" || !parent.frames[SecLineFrame])SecLineFrame=DocTargetFrame=FirstLineFrame}
if(DocTargetFrame =="" || !parent.frames[DocTargetFrame])DocTargetFrame=SecLineFrame;
if(WebMasterCheck){ if(!Check('Menu',NoOffFirstLineMenus)){status='bui ld aborted';return}}
FrstLoc=FirstLineFrame!=""?parent.frames[FirstLineFrame]:window;
ScLoc=SecLineFrame!=""?parent.frames[SecLineFrame]:window;
DcLoc=DocTargetFrame!=""?parent.frames[DocTargetFrame]:window;
if (FrstLoc==ScLoc) AcrssFrms=0;
if (AcrssFrms)FirstLineHorizontal=MenuFramesVertical? 0:1;
if(Nav4){ CntrTxt=MenuTextCentered!='left'?"<div align='"+MenuTextCentered+"'>":"";
TxtClose="</font>"+MenuTextCentered!='left'?"</div>":""}}
FirstColPos=Nav4?FrstLoc.document:FrstLoc.document .body;
SecColPos=Nav4?ScLoc.document:ScLoc.document.body;
DocColPos=Nav4?DcLoc.document:ScLoc.document.body;
if (TakeOverBgColor)FirstColPos.bgColor=AcrssFrms?Sec ColPos.bgColor:DocColPos.bgColor;
if(MenuCentered=='justify'&&FirstLineHorizontal)Cl cJus();
if(FrstCreat){
FrstCntnr=CreateMenuStructure('Menu',NoOffFirstLin eMenus);
FrstCreat=AcrssFrms?0:1}
else CreateMenuStructureAgain('Menu',NoOffFirstLineMenu s);
PosMenu(FrstCntnr,StartTop,StartLeft);
IniFlg=1;
Initiate();
Creatd=1;
if (AcrssFrms) //Added for Opera
{ //Added for Opera
ScLdAgainWin=ExpYes?ScLoc.document.body:ScLoc;
ScLdAgainWin.onunload=UnLoaded;
} //Added for Opera
Trigger.onresize=Nav4?ReDoWhole:RePos;
AfterBuild();
if(MenuVerticalCentered=='static'&&!AcrssFrms)setI nterval('KeepPos()',250);
status='Menu ready for use'}
function KeepPos(){
var TS=ExpYes?FrstLoc.document.body.scrollTop:FrstLoc. pageYOffset;
if(TS!=StaticPos){
FCStyle.top=FrstCntnr.OrgTop=StartTop+TS;StaticPos =TS}}
function ClcJus(){
var a=BorderBtwnElmnts?1:2,b=BorderBtwnElmnts?BorderWi dth:0;
var Size=Math.round(((FrstWinWdth-a*BorderWidth)/NoOffFirstLineMenus)-b),i,j;
for(i=1;i<NoOffFirstLineMenus+1;i++){j=eval('Menu' +i);j[5]=Size}
StartLeft=0}
function ClcTrgt(){
var TLoc=Nav4?FrstLoc.document.layers[TargetLoc]:DomYes?FrstLoc.document.getElementById(TargetLoc) :FrstLoc.document.all[TargetLoc];
StartTop=M_StrtTp;
StartLeft=M_StrtLft;
if(DomYes){
while(TLoc){StartTop+=TLoc.offsetTop;StartLeft+=TL oc.offsetLeft;TLoc=TLoc.offsetParent}}
else{ StartTop+=Nav4?TLoc.pageY:TLoc.offsetTop;StartLeft +=Nav4?TLoc.pageX:TLoc.offsetLeft}}
function ClcLft(){
if(MenuCentered!='left'&&MenuCentered!='justify'){
var Size=FrstWinWdth-(!Nav4?parseInt(FrstCntnr.style.width):FrstCntnr.c lip.width);
StartLeft+=MenuCentered=='right'?Size:Size/2}}
function ClcTp(){
if(MenuVerticalCentered!='top'&&MenuVerticalCenter ed!='static'){
var Size=FrstWinHght-(!Nav4?parseInt(FrstCntnr.style.height):FrstCntnr. clip.height);
StartTop=M_StrtTp;
StartTop+=MenuVerticalCentered=='bottom'?Size:Size/2}}
function PosMenu(CntnrPntr,Tp,Lt){
var Topi,Lefti,Hori;
var Cntnr=CntnrPntr;
var Mmbr=Cntnr.FrstMbr;
var CntnrStyle=!Nav4?Cntnr.style:Cntnr;
var MmbrStyle=!Nav4?Mmbr.style:Mmbr;
var PadL=Mmbr.value.indexOf('<')==-1?LftXtra:0;
var PadT=Mmbr.value.indexOf('<')==-1?TpXtra:0;
var MmbrWt=!Nav4?parseInt(MmbrStyle.width)+PadL:MmbrSt yle.clip.width;
var MmbrHt=!Nav4?parseInt(MmbrStyle.height)+PadT:MmbrS tyle.clip.height;
var CntnrWt=!Nav4?parseInt(CntnrStyle.width):CntnrStyl e.clip.width;
var CntnrHt=!Nav4?parseInt(CntnrStyle.height):CntnrSty le.clip.height;
var SubTp,SubLt;
RcrsLvl++;
if (RcrsLvl==1 && AcrssFrms)!MenuFramesVertical?Tp=FrstWinHght-CntnrHt+(Nav4?4:0):Lt=RightToLeft?0:FrstWinWdth-CntnrWt+(Nav4?4:0);
if (RcrsLvl==2 && AcrssFrms)!MenuFramesVertical?Tp=0:Lt=RightToLeft? ScWinWdth-CntnrWt:0;
if (RcrsLvl==2 && AcrssFrms){Tp+=VerCorrect;Lt+=HorCorrect}
CntnrStyle.top=RcrsLvl==1?Tp:0;
Cntnr.OrgTop=Tp;
CntnrStyle.left=RcrsLvl==1?Lt:0;
Cntnr.OrgLeft=Lt;
if (RcrsLvl==1 && FirstLineHorizontal){
Hori=1;Lefti=CntnrWt-MmbrWt-2*BorderWidth;Topi=0}
else{ Hori=Lefti=0;Topi=CntnrHt-MmbrHt-2*BorderWidth}
while(Mmbr!=null){
MmbrStyle.left=Lefti+BorderWidth;
MmbrStyle.top=Topi+BorderWidth;
if(Nav4)Mmbr.CmdLyr.moveTo(Lefti+BorderWidth,Topi+ BorderWidth);
if(Mmbr.ChildCntnr){
if(RightToLeft)ChldCntnrWdth=Nav4?Mmbr.ChildCntnr. clip.width:parseInt(Mmbr.ChildCntnr.style.width);
if(Hori){ SubTp=Topi+MmbrHt+2*BorderWidth;
SubLt=RightToLeft?Lefti+MmbrWt-ChldCntnrWdth:Lefti}
else{ SubLt=RightToLeft?Lefti-ChldCntnrWdth+ChildOverlap*MmbrWt+BorderWidth:Left i+(1-ChildOverlap)*MmbrWt+BorderWidth;
SubTp=RcrsLvl==1&&AcrssFrms?Topi:Topi+ChildVertica lOverlap*MmbrHt}
PosMenu(Mmbr.ChildCntnr,SubTp,SubLt)}
Mmbr=Mmbr.PrvMbr;
if(Mmbr){ MmbrStyle=!Nav4?Mmbr.style:Mmbr;
Hori?Lefti-=BorderBtwnElmnts?(MmbrWt+BorderWidth):(MmbrWt):To pi-=BorderBtwnElmnts?(MmbrHt+BorderWidth):(MmbrHt)}}
RcrsLvl--}
function Initiate(){
if(IniFlg){ Init(FrstCntnr);IniFlg=0;
if(ShwFlg)AfterCloseAll();ShwFlg=0}}
function Init(CntnrPntr){
var Mmbr=CntnrPntr.FrstMbr;
var MCStyle=Nav4?CntnrPntr:CntnrPntr.style;
RcrsLvl++;
MCStyle.visibility=RcrsLvl==1?M_Show:M_Hide;
while(Mmbr!=null){
if(Mmbr.Hilite){Mmbr.Hilite=0;if(KeepHilite)LowIte m(Mmbr)}
if(Mmbr.ChildCntnr) Init(Mmbr.ChildCntnr);
Mmbr=Mmbr.PrvMbr}
RcrsLvl--}
function ClearAllChilds(Pntr){
var CPCCStyle;
while (Pntr){
if(Pntr.Hilite){
Pntr.Hilite=0;
if(KeepHilite)LowItem(Pntr);
if(Pntr.ChildCntnr){
CPCCStyle=Nav4?Pntr.ChildCntnr:Pntr.ChildCntnr.sty le;
CPCCStyle.visibility=M_Hide;
ClearAllChilds(Pntr.ChildCntnr.FrstMbr)}
break}
Pntr=Pntr.PrvMbr}}
function GoTo(){
if(this.LinkTxt){
status='';
var HP=Nav4?this.LowLyr:this;
LowItem(HP);
this.LinkTxt.indexOf('javascript:')!=-1?eval(this.LinkTxt):DcLoc.location.href=this.Link Txt}}
function HiliteItem(P){
if(Nav4){
if(P.ro)P.document.images[P.rid].src=P.ri2;
else{ if(P.HiBck)P.bgColor=P.HiBck;
if(P.value.indexOf('<img')==-1){
P.document.write(P.Ovalue);
P.document.close()}}}
else{ if(P.ro){ var Lc=P.Level==1?FrstLoc:ScLoc;
Lc.document.images[P.rid].src=P.ri2}
else{ if(P.HiBck)P.style.backgroundColor=P.HiBck;
if(P.HiFntClr)P.style.color=P.HiFntClr}}
P.Hilite=1}
function LowItem(P){
if(P.ro){ if(Nav4)P.document.images[P.rid].src=P.ri1;
else{ var Lc=P.Level==1?FrstLoc:ScLoc;
Lc.document.images[P.rid].src=P.ri1}}
else{ if(Nav4){ if(P.LoBck)P.bgColor=P.LoBck;
P.document.write(P.value);
else{ if(P.LoBck)P.style.backgroundColor=P.LoBck;
if(P.LwFntClr)P.style.color=P.LwFntClr}}}
function OpenMenu(){
if(!Loadd||!Creatd) return;
var TpScrlld=ExpYes?ScLoc.document.body.scrollTop:ScLo c.pageYOffset;
var LScrlld=ExpYes?ScLoc.document.body.scrollLeft:ScLo c.pageXOffset;
var CCnt=Nav4?this.LowLyr.ChildCntnr:this.ChildCntnr;
var ThisHt=Nav4?this.clip.height:parseInt(this.style.h eight);
var ThisWt=Nav4?this.clip.width:parseInt(this.style.wi dth);
var ThisLft=AcrssFrms&&this.Level==1&&!FirstLineHorizo ntal?0:Nav4?this.Container.left:parseInt(this.Cont ainer.style.left);
var ThisTp=AcrssFrms&&this.Level==1&&FirstLineHorizont al?0:Nav4?this.Container.top:parseInt(this.Contain er.style.top);
CurrntOvr=this;
IniFlg=0;
ClearAllChilds(this.Container.FrstMbr);
HiliteItem(HP);
if(CCnt!=null){
if(!ShwFlg){ShwFlg=1; BeforeFirstOpen()}
var CCW=Nav4?this.LowLyr.ChildCntnr.clip.width:parseIn t(this.ChildCntnr.style.width);
var CCH=Nav4?this.LowLyr.ChildCntnr.clip.height:parseI nt(this.ChildCntnr.style.height);
var ChCntTL=Nav4?this.LowLyr.ChildCntnr:this.ChildCntn r.style;
var SubLt=AcrssFrms&&this.Level==1?CCnt.OrgLeft+ThisLf t+LScrlld:CCnt.OrgLeft+ThisLft;
var SubTp=AcrssFrms&&this.Level==1?CCnt.OrgTop+ThisTp+ TpScrlld:CCnt.OrgTop+ThisTp;
if(MenuWrap){
if(RightToLeft){
if(SubLt<LScrlld)SubLt=this.Level==1?LScrlld:SubLt +(CCW+(1-2*ChildOverlap)*ThisWt);
if(SubLt+CCW>ScWinWdth+LScrlld)SubLt=ScWinWdth+LSc rlld-CCW}
else{ if(SubLt+CCW>ScWinWdth+LScrlld)SubLt=this.Level==1 ?ScWinWdth+LScrlld-CCW:SubLt-(CCW+(1-2*ChildOverlap)*ThisWt);
if(SubLt<LScrlld)SubLt=LScrlld}
if(SubTp+CCH>TpScrlld+ScWinHght)SubTp=this.Level== 1?SubTp=TpScrlld+ScWinHght-CCH:SubTp-CCH+(1-2*ChildVerticalOverlap)*ThisHt;
if(SubTp<TpScrlld)SubTp=TpScrlld}
ChCntTL.top=SubTp;ChCntTL.left=SubLt;ChCntTL.visib ility=M_Show}
status=this.LinkTxt}
function OpenMenuClick(){
CurrntOvr=this;
IniFlg=0;
HiliteItem(HP);
function CloseMenu(){
if(!KeepHilite){
LowItem(HP)}
status='';
if(this==CurrntOvr){
IniFlg=1;
CloseTmr=setTimeout('Initiate(CurrntOvr)',Dissapea rDelay)}}
function CntnrSetUp(Wdth,Hght,NoOff){
var x=RcrsLvl==1?BorderColor:BorderSubColor;
this.FrstMbr=null;
this.OrgLeft=this.OrgTop=0;
if(x)this.bgColor=x;
if(Nav4){ this.visibility='hide';
this.resizeTo(Wdth,Hght)}
else{ if(x)this.style.backgroundColor=x;
this.style.width=Wdth;
this.style.height=Hght;
this.style.fontFamily=FontFamily;
this.style.fontWeight=FontBold?'bold':'normal';
this.style.fontStyle=FontItalic?'italic':'normal';
this.style.fontSize=FontSize+'pt';
this.style.zIndex=RcrsLvl+Ztop}}
function MbrSetUp(MmbrCntnr,PrMmbr,WhatMenu,Wdth,Hght){
var Location=RcrsLvl==1?FrstLoc:ScLoc;
var MemVal=eval(WhatMenu+'[0]');
var t,T,L,W,H,S;
var a,b,c,d;
this.PrvMbr=PrMmbr;
this.Level=RcrsLvl;
this.LinkTxt=eval(WhatMenu+'[1]');
this.Container=MmbrCntnr;
this.ChildCntnr=null;
this.Hilite=0;
this.style.overflow='hidden';
this.style.cursor=ExpYes&&(this.LinkTxt||(RcrsLvl= =1&&UnfoldsOnClick))?'hand':'default';
this.ro=0;
if(MemVal.indexOf('rollover')!=-1){
this.ro=1;
this.ri1=MemVal.substring(MemVal.indexOf(':')+1,Me mVal.lastIndexOf(':'));
this.ri2=MemVal.substring(MemVal.lastIndexOf(':')+ 1,MemVal.length);
this.rid=WhatMenu+'i';MemVal="[img]"+this.ri1+"[/img]"}
this.value=MemVal;
if(RcrsLvl==1){
a=LowBgColor;
b=HighBgColor;
c=FontLowColor;
d=FontHighColor}
else{ a=LowSubBgColor;
b=HighSubBgColor;
c=FontSubLowColor;
d=FontSubHighColor}
this.LoBck=a;
this.LwFntClr=c;
this.HiBck=b;
this.HiFntClr=d;
this.style.color=this.LwFntClr;
if(this.LoBck)this.style.backgroundColor=this.LoBc k;
this.style.textAlign=MenuTextCentered;
if(eval(WhatMenu+'[2]'))this.style.backgroundImage="url(\'"+eval(WhatMe nu+'[2]')+"\')";
if(MemVal.indexOf('<')==-1){
this.style.width=Wdth-LftXtra;
this.style.height=Hght-TpXtra;
this.style.paddingLeft=LeftPaddng;
this.style.paddingTop=TopPaddng}
else{ this.style.width=Wdth;
this.style.height=Hght}
if(MemVal.indexOf('<')==-1&&DomYes){
t=Location.document.createTextNode(MemVal);
this.appendChild(t)}
else this.innerHTML=MemVal;
if(eval(WhatMenu+'[3]')&&ShowArrow){
a=RcrsLvl==1&&FirstLineHorizontal?3:RightToLeft?6: 0;
S=Arrws[a];
W=Arrws[a+1];
H=Arrws[a+2];
T=RcrsLvl==1&&FirstLineHorizontal?Hght-H-2:(Hght-H)/2;
L=RightToLeft?2:Wdth-W-2;
if(DomYes){
t=Location.document.createElement('img');
this.appendChild(t);
t.style.position='absolute';
t.src=S;
t.style.width=W;
t.style.height=H;
t.style.top=T;
t.style.left=L}
else{ MemVal+="<div style='position:absolute; top:"+T+"; left:"+L+"; width:"+W+"; height:"+H+";visibility:inherit'>[img]"+S+"[/img]</div>";
this.innerHTML=MemVal}}
if(ExpYes){this.onselectstart=CnclSlct;
this.onmouseover=RcrsLvl==1&&UnfoldsOnClick?OpenMe nuClick:OpenMenu;
this.onmouseout=CloseMenu;
this.onclick=RcrsLvl==1&&UnfoldsOnClick&&eval(What Menu+'[3]')?OpenMenu:GoTo }
else{ RcrsLvl==1&&UnfoldsOnClick?this.addEventListener(' mouseover',OpenMenuClick,false):this.addEventListe ner('mouseover',OpenMenu,false);
this.addEventListener('mouseout',CloseMenu,false);
RcrsLvl==1&&UnfoldsOnClick&&eval(WhatMenu+'[3]')?this.addEventListener('click',OpenMenu,false):t his.addEventListener('click',GoTo,false)}}
function NavMbrSetUp(MmbrCntnr,PrMmbr,WhatMenu,Wdth,Hght){
var a,b,c,d;
if(RcrsLvl==1){
a=LowBgColor;
b=HighBgColor;
c=FontLowColor;
d=FontHighColor}
else { a=LowSubBgColor;
b=HighSubBgColor;
c=FontSubLowColor;
d=FontSubHighColor }
this.value=eval(WhatMenu+'[0]');
this.ro=0;
if(this.value.indexOf('rollover')!=-1){
this.ro=1;
this.ri1=this.value.substring(this.value.indexOf(' :')+1,this.value.lastIndexOf(':'));
this.ri2=this.value.substring(this.value.lastIndex Of(':')+1,this.value.length);
this.rid=WhatMenu+'i';this.value="[img]"+this.ri1+"[/img]"}
if(LeftPaddng&&this.value.indexOf('<')==-1&&MenuTextCentered=='left')this.value='&nbsp\;'+t his.value;
if(FontBold)this.value=this.value.bold();
if(FontItalic)this.value=this.value.italics();
this.Ovalue=this.value;
this.value=this.value.fontcolor(c);
this.Ovalue=this.Ovalue.fontcolor(d);
this.value=CntrTxt+"<font face='"+FontFamily+"' point-size='"+FontSize+"'>"+this.value+TxtClose;
this.Ovalue=CntrTxt+"<font face='"+FontFamily+"' point-size='"+FontSize+"'>"+this.Ovalue+TxtClose;
this.LoBck=a;
this.HiBck=b;
this.PrvMbr=PrMmbr;
this.Hilite=0;
this.visibility='inherit';
if(this.LoBck)this.bgColor=this.LoBck;
this.resizeTo(Wdth,Hght);
if(!AcrssFrms&&eval(WhatMenu+'[2]'))this.background.src=eval(WhatMenu+'[2]');
this.document.write(this.value);
this.document.close();
this.CmdLyr=new Layer(Wdth,MmbrCntnr);
this.CmdLyr.Level=RcrsLvl;
this.CmdLyr.LinkTxt=eval(WhatMenu+'[1]');
this.CmdLyr.visibility='inherit';
this.CmdLyr.onmouseover=RcrsLvl==1&&UnfoldsOnClick ?OpenMenuClick:OpenMenu;
this.CmdLyr.onmouseout=CloseMenu;
this.CmdLyr.captureEvents(Event.MOUSEUP);
this.CmdLyr.onmouseup=RcrsLvl==1&&UnfoldsOnClick&& eval(WhatMenu+'[3]')?OpenMenu:GoTo;
this.CmdLyr.LowLyr=this;
this.CmdLyr.resizeTo(Wdth,Hght);
this.CmdLyr.Container=MmbrCntnr;
this.CmdLyr.ImgLyr=new Layer(Arrws[a+1],this.CmdLyr);
this.CmdLyr.ImgLyr.visibility='inherit';
this.CmdLyr.ImgLyr.top=RcrsLvl==1&&FirstLineHorizo ntal?Hght-Arrws[a+2]-2:(Hght-Arrws[a+2])/2;
this.CmdLyr.ImgLyr.left=RightToLeft?2:Wdth-Arrws[a+1]-2;
this.CmdLyr.ImgLyr.width=Arrws[a+1];
this.CmdLyr.ImgLyr.height=Arrws[a+2];
ImgStr="[img]"+Arrws[a]+"[/img]";
this.CmdLyr.ImgLyr.document.write(ImgStr);
this.CmdLyr.ImgLyr.document.close()}}
function CreateMenuStructure(MName,NumberOf){
RcrsLvl++;
var i,NoOffSubs,Mbr,Wdth=0,Hght=0;
var PrvMmbr=null;
var WMnu=MName+'1';
var MenuWidth=eval(WMnu+'[5]');
var MenuHeight=eval(WMnu+'[4]');
if (RcrsLvl==1&&FirstLineHorizontal){
for(i=1;i<NumberOf+1;i++){
WMnu=MName+eval(i);
Wdth=eval(WMnu+'[5]')?Wdth+eval(WMnu+'[5]'):Wdth+MenuWidth}
Wdth=BorderBtwnElmnts?Wdth+(NumberOf+1)*BorderWidt h:Wdth+2*BorderWidth;Hght=MenuHeight+2*BorderWidth }
else{ for(i=1;i<NumberOf+1;i++){
WMnu=MName+eval(i);
Hght=eval(WMnu+'[4]')?Hght+eval(WMnu+'[4]'):Hght+MenuHeight}
Hght=BorderBtwnElmnts?Hght+(NumberOf+1)*BorderWidt h:Hght+2*BorderWidth;Wdth=MenuWidth+2*BorderWidth}
if(DomYes){
var MmbrCntnr=Location.document.createElement("div");
MmbrCntnr.style.position='absolute';
MmbrCntnr.style.visibility='hidden';
Location.document.body.appendChild(MmbrCntnr)}
else{ if(Nav4) var MmbrCntnr=new Layer(Wdth,Location)
else{ WMnu+='c';
Location.document.body.insertAdjacentHTML("AfterBe gin","<div id='"+WMnu+"' style='visibility:hidden; position:absolute;'><\/div>");
var MmbrCntnr=Location.document.all[WMnu]}}
MmbrCntnr.SetUp=CntnrSetUp;
MmbrCntnr.SetUp(Wdth,Hght,NumberOf);
if(Exp4){ MmbrCntnr.InnerString='';
WMnu=MName+eval(i);
MmbrCntnr.InnerString+="<div id='"+WMnu+"' style='position:absolute;'><\/div>"}
MmbrCntnr.innerHTML=MmbrCntnr.InnerString}
WMnu=MName+eval(i);
NoOffSubs=eval(WMnu+'[3]');
Wdth=RcrsLvl==1&&FirstLineHorizontal?eval(WMnu+'[5]')?eval(WMnu+'[5]'):MenuWidth:MenuWidth;
Hght=RcrsLvl==1&&FirstLineHorizontal?MenuHeight:ev al(WMnu+'[4]')?eval(WMnu+'[4]'):MenuHeight;
if(DomYes){
Mbr=Location.document.createElement("div");
Mbr.style.position='absolute';
Mbr.style.visibility='inherit';
MmbrCntnr.appendChild(Mbr)}
else Mbr=Nav4?new Layer(Wdth,MmbrCntnr):Location.document.all[WMnu];
Mbr.SetUp=Nav4?NavMbrSetUp:MbrSetUp;
Mbr.SetUp(MmbrCntnr,PrvMmbr,WMnu,Wdth,Hght);
if(NoOffSubs) Mbr.ChildCntnr=CreateMenuStructure(WMnu+'_',NoOffS ubs);
PrvMmbr=Mbr}
MmbrCntnr.FrstMbr=Mbr;
RcrsLvl--;
return(MmbrCntnr)}
function CreateMenuStructureAgain(MName,NumberOf){
var i,WMnu,NoOffSubs,PrvMmbr,Mbr=FrstCntnr.FrstMbr;
RcrsLvl++;
for(i=NumberOf;i>0;i--){
WMnu=MName+eval(i);
PrvMmbr=Mbr;
if(NoOffSubs)Mbr.ChildCntnr=CreateMenuStructure(WM nu+'_',NoOffSubs);
Mbr=Mbr.PrvMbr}
RcrsLvl--}
function BeforeStart(){return}
function AfterBuild(){return}
function BeforeFirstOpen(){return}
function AfterCloseAll(){return}
</script>
wenn ich dort, wo das ziel rein soll nun hauptframe schreibe, öffnet sich der link in der selben seite, aber nicht im frame.
hat jemand eine idee, woran dies liegt?
vielen dank!!!
grüße
börni
