Thema: Script: Uhrzeit und Datum in der Statuszeile
    Standard Script: Uhrzeit und Datum in der Statuszeile
    Dieses Java-Script zeigt den Besuchern die Uhrzeit und Datum in der Statuszeile an.
    <!-- vor alten Browsern verstecken --
    /* Uhrzeit und Datum in der Statuszeile */
    var timerID = null;
    var timerRunning = false;
    // Called by both onLoad in BODY tag, and Resume button.
    function startclock &#40;&#41;
       &#123;
       // Make sure the clock is stopped
       stopclock&#40;&#41;;
       time&#40;&#41;;
    // Kills clock.
    function stopclock &#40;&#41;
       &#123;
       if&#40;timerRunning&#41;
          clearTimeout&#40;timerID&#41;;
    function time &#40;&#41;
       &#123;
       var now = new Date&#40;&#41;;
       var yr = now.getYear&#40;&#41;;
    if &#40;yr < 2000&#41; yr +=1900
       var mName = now.getMonth&#40;&#41; + 1;
       var dName = now.getDay&#40;&#41; + 1;
       var dayNr = now.getDate&#40;&#41;;
       var hours = now.getHours&#40;&#41;;
       var minutes = &#40;&#40;now.getMinutes&#40;&#41; < 10&#41; ? "&#58;0" &#58; "&#58;"&#41; + now.getMinutes&#40;&#41;;
       var seconds = &#40;&#40;now.getSeconds&#40;&#41; < 10&#41; ? "&#58;0" &#58; "&#58;"&#41; + now.getSeconds&#40;&#41;;
       if&#40;dName==1&#41; Day = "Sonntag";
       if&#40;dName==2&#41; Day = "Montag";
       if&#40;dName==3&#41; Day = "Dienstag";
       if&#40;dName==4&#41; Day = "Mittwoch";
       if&#40;dName==5&#41; Day = "Donnerstag";
       if&#40;dName==6&#41; Day = "Freitag";
       if&#40;dName==7&#41; Day = "Samstag";
       if&#40;mName==1&#41; Month="Januar";
       if&#40;mName==2&#41; Month="Februar";
       if&#40;mName==3&#41; Month="März";
       if&#40;mName==4&#41; Month="April";
       if&#40;mName==5&#41; Month="Mai";
       if&#40;mName==6&#41; Month="Juni";
       if&#40;mName==7&#41; Month="Juli";
       if&#40;mName==8&#41; Month="August";
       if&#40;mName==9&#41; Month="September";
       if&#40;mName==10&#41; Month="Oktober";
       if&#40;mName==11&#41; Month="November";
       if&#40;mName==12&#41; Month="Dezember";
       // String to display current date.
       var DayDateTime=&#40;" "
           + Day
           + dayNr
           + Month
           + yr
           + hours
           + minutes
           + seconds
            &#41;;
       // Displays Day-Date-Time on the staus bar.
       window.status=DayDateTime;
       timerID = setTimeout&#40;"time&#40;&#41;",1000&#41;;
       timerRunning = true;
    // Stops clock and clears status bar.
    function clearStatus&#40;&#41;
       &#123;
       window.status=" ";
    // -- End Hiding Here -->
    </script>
    Diesen Teil in den Body Bereich der Webseite, wo auch zb die Hintergrundfarbe und Textlinks eingetragen werden
    onload="startclock&#40;&#41;"
    bimbel83
    soweit klappt das ja richtig gut, dein skript, kannst du mir auch verraten, wie man das hinbekommt, das man immer die uhr sieht (auch wenn ich auf einen link gehe)?
    entweder du schreibst es in eine extra file und machst in jede file ein include befehl, oder du machst es gleich per .js file...
    Ist zwar jetzt schon eine älterer Beitrag hier,
    er wurd mir aber vor ein paar Tagen angezeigt,
    als wenn hier etwas neu gepostet wurde. warum auch immer.
    Egal, aber als ich diesen Script sah dachte ich mir,
    dies geht doch auch viel kürzer.
    Folgenden Script hatte ich mal auf meiner HP.
    Ich hatte ihn auf der home.html eingebaut'und die Zeit wurde auf jeder Seite angezeigt.
    Einziger Nachteil, funktioniert nur im IE.
    Vielleicht weiß ja jemand, wie man das ändern kann.
    Ach ja, er wird im head unter den Metatags und dem Titel eingegfügt.
    <script>
    var text="Shila´s Dreamland "
    var geschwindigkeit=200
    var timer
    function zeit&#40;&#41; &#123;
        thistime= new Date&#40;&#41;
    	var hours=thistime.getHours&#40;&#41;
    	var minutes=thistime.getMinutes&#40;&#41;
    	var seconds=thistime.getSeconds&#40;&#41;
    	if &#40;eval&#40;hours&#41; <10&#41; &#123;hours="0"+hours&#125;
    	if &#40;eval&#40;minutes&#41; < 10&#41; &#123;minutes="0"+minutes&#125;
    	if &#40;seconds < 10&#41; &#123;seconds="0"+seconds&#125;
    	thistime = hours+"&#58;"+minutes+"&#58;"+seconds
        if &#40;document.all&#41; &#123;
            document.title=text+thistime
            timer = setTimeout&#40;"zeit&#40;&#41;",geschwindigkeit&#41;
    window.onload=zeit
    </script>
    LG Shila
  1. Besucherzähler, Uhrzeit, Datum?
    Von Ericfischer im Forum HTML & CSS Forum
    Letzter Beitrag: 24.04.2007, 09:43
  2. Datum-Uhrzeit Script
    Von K.C. im Forum Script-Archiv
    Letzter Beitrag: 12.11.2006, 21:19
  3. Fehler bei Datum/Uhrzeit script
    Von ad3nau im Forum HTML & CSS Forum
    Letzter Beitrag: 19.07.2006, 22:51
  4. Datum und Uhrzeit nebeneinander
    Letzter Beitrag: 19.07.2006, 13:27
  5. Antworten: 14
    Letzter Beitrag: 14.09.2004, 21:50
